Windows 10 - Upgrade unable to via CMD
Trying to upgrade Node -red on my Windows 10 PC.
I am using CDM and not powershell and as the directory is C:\Program Files\nodejs
Error from Powershell, I think it is due the the space in the directory structure "Program Files"
PS C:> cd /Program Files
Set-Location : A positional parameter cannot be found that accepts argument 'Files'.
At line:1 char:1
+ cd /Program Files
    • CategoryInfo : InvalidArgument: (:slight_smile: [Set-Location], ParameterBindingException*
    • FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.SetLocationCommand*
If I run in CMD I get the following:
C:\Program Files\nodejs>npm install -g --unsafe-perm node-red
npm WARN deprecated mkdirp@0.5.4: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
C:\Users\Johan\AppData\Roaming\npm\node-red-pi -> C:\Users\Johan\AppData\Roaming\npm\node_modules\node-red\bin\node-red-pi
C:\Users\Johan\AppData\Roaming\npm\node-red -> C:\Users\Johan\AppData\Roaming\npm\node_modules\node-red\red.js
> bcrypt@3.0.6 install C:\Users\Johan\AppData\Roaming\npm\node_modules\node-red\node_modules\bcrypt
> node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Using request for node-pre-gyp https download
[bcrypt] Success: "C:\Users\Johan\AppData\Roaming\npm\node_modules\node-red\node_modules\bcrypt\lib\binding\bcrypt_lib.node" is installed via remote
+ node-red@1.0.4
added 331 packages in 174.52s
C:\Program Files\nodejs>node --version && npm --version
v8.11.2
5.6.0
Any assistance will be appreciated. Thank you
use quotes for path with space in them
You install looks to have worked - have you tried running node-red and checking the version number on start up (or in the hamburger menu)
EDIT: also, for understanding sake, npm -g means install globally (i.e. no need to CD into program files)
Thank you for you assistance
