I will save the data in node-red to a file and then send the data here to sqle according to the old to new. Then I will delete the data I sent from the file.
I would appreciate if you can help.
Hi.
What data?
What format?
what is sqle?
Is there a reason for writing to file in the first place?
What have you done so far? where are you stuck?
Another candidate for a flimflam valve I think ![]()
Hello I collect data via Modbus TCP. We can record in the format we want. I am using mssql.
So far, I am writing the data to a file, but I could not write and delete the file sequentially.
In addition, I am currently accumulating the data in an array. I am writing one by one from there, but this fills the ram. And node red crashes (I think this is it).
Thank you for your support.
Can you clarify this. Provide a screenshot of the flow. Also, provide a screenshot of the write node configuration.
