I'm trying to get node-red-contrib-miio-roborock to work. The node can't connect to my vacuum. The error message says that the token might be wrong. I'm sure, the token is correct, because I'm using the same token in FHEM to control the vakuum and it works fine there.... What could be the reason that I cant connect and control my vacuum?
