Hi All !
I have a problem, I want to use MQTT connect PC and ADAM-6717 . I use MQTT on Node-Red in localhost, it work. but I try to use MQTT in ADAM-6717, it doesn't work. I have set my firewall port 1883 open. ping ADAM-6717 ip can work , telnet ADAM-6717 ip also can work.
Charlie
Have you looked at the device manual for this application?
https://support.advantech-bb.com/download/sr/1-1WG6CWH
Hi Gunner
Yes, I had try .The example Broker address I set 192.168.50.211:1883.
What broker type and version are you running?
If it is mosquito v2 then you will need to adjust its config to permit external connection.
Been covered many times on the forum and elsewhere. Search mosquito v2
