Hi all, new to NR. Great product!
I am trying to do the following: programmatically (re)connect a NR installation to its HA (after a backup). I need an automatic installation of HA Core + NR. I know I can do it from UI, but I want to do it programmatically if possible. I want to pretty much 'unclick' the "I use the HA add-on" and set a base URL and token.
What I tried:
curl -H "Accept: application/json" http://myhost.local:1880/nodes | jq .
"id": "f9263a0dce1fe118",
"type": "tab",
"label": "XYZ",
"disabled": false,
"info": "",
"env": []
"id": "86b445a.684a7b8",
"type": "server",
"name": "Home Assistant",
"version": 2,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": 30
I can retrieve the first flow, but not not the HA one:
curl -H "Accept: application/json" http://myhost.local:1880/flow/f9263a0dce1fe118
works, but:
curl -H "Accept: application/json" "http://myhost.local:1880/flow/86b445a.684a7b8"
{"code":"not_found","message":"Error"}%
NR audit logs:
16 Jan 01:15:50 - [audit] {"event":"flow.get","id":"86b445a.684a7b8","error":"not_found","level":98,"path":"/flow/86b445a.684a7b8","ip":"192.168.1.187","timestamp":1642295750479}
16 Jan 01:15:50 - [audit] {"event":"api.error","error":"not_found","message":"Error","level":98,"path":"/flow/86b445a.684a7b8","ip":"192.168.1.187","timestamp":1642295750483}
Any idea what is the problem/how can I achieve my goal?
