Arduino Nano RP2040 failing to connect to Aedes MQTT Broker
I am new to node-red and IoT databases. I am in frustration as i cannot figure out why i cannot connect to an MQTT broker using my arduino nano rp2040. I can successfully connect on node-red using the aedes MQTT broker. I'll attach both my Arduino code and node-red code below
Any help would be much provided in how to access this.
#include <PubSubClient.h>
#include <SPI.h>
#include <WiFiNINA.h>
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID
char pass[] = SECRET_PASS;    // your network password
int status = WL_IDLE_STATUS;     // the WiFi radio's status
const char* mqtt_server = "192.168.1.12";
WiFiClient rp2040Client;
PubSubClient client(rp2040Client);
unsigned long lastMillis = 0;
void wificonnect() {
  // Connecting to a WiFi network
  WiFi.begin(ssid, pass);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
void reconnect() {
  // Loop until we're reconnected
  Serial.println("In reconnect...");
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("hello")) {
      Serial.println("connected");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      delay(5000);
*void messageReceived(String &topic, String &payload) {
 Serial.println("incoming: " + topic + " - " + payload);
 if (topic == "/hello") {
   if (payload == "open") {
     Serial.println("open");
     digitalWrite(LED_BUILTIN, HIGH);
   } else if (payload == "closed") {
     Serial.println("closed");
     digitalWrite(LED_BUILTIN, LOW);
void setup() {
  //Initialize serial and wait for port to open:
  Serial.begin(115200);
//  wificonnect();
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  client.setServer(mqtt_server, 1883);
void loop() {
  if (!client.connected()) {
    reconnect();
 // publish a message roughly every second.
 if (millis() - lastMillis > 1000) {
   lastMillis = millis();
   client.publish("/hello", "world"); //PUBLISH TO TOPIC /hello MSG world
        "id": "6a69d8ab81cc5798",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": ""
        "id": "3379850d.902a8a",
        "type": "mqtt in",
        "z": "6a69d8ab81cc5798",
        "topic": "#",
        "qos": "0",
        "datatype": "auto",
        "broker": "cce024b53e0d96d6",
        "nl": false,
        "rap": false,
        "x": 115,
        "y": 260,
                "9b59d15d.6d1d28"
        "l": false
        "id": "9b59d15d.6d1d28",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "x": 450,
        "y": 300,
        "id": "6ff9ea89.aac6e4",
        "type": "inject",
        "name": "inject \"open\" command",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "/hello",
        "payload": "open",
        "payloadType": "str",
        "x": 200,
        "y": 400,
                "97f6e1c5.ab547"
        "id": "97f6e1c5.ab547",
        "type": "mqtt out",
        "topic": "",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 500,
        "y": 420,
        "id": "c8e9cb97.9ddfb",
        "type": "inject",
        "name": "inject \"closed\" command",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "/hello",
        "payload": "closed",
        "x": 210,
        "y": 480,
                "97f6e1c5.ab547"
        "id": "bff256acbf91a40a",
        "type": "aedes broker",
        "mqtt_port": 1883,
        "mqtt_ws_bind": "port",
        "mqtt_ws_port": null,
        "mqtt_ws_path": "",
        "cert": "",
        "key": "",
        "certname": "",
        "keyname": "",
        "dburl": "",
        "usetls": false,
        "x": 300,
        "y": 160,
        "id": "cce024b53e0d96d6",
        "type": "mqtt-broker",
        "name": "Aedes",
        "broker": "localhost",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
  1. The Aedes brnodeI would suggest you install mosquitto as your broker and remove the Aedes node. Mosquitto is easy to install* and use and many on the forum use it. Here is a tutorial for installing it: https://www.arrow.com/en/research-and-events/articles/mqtt-tutorial
  2. do not use leading / as part of the topic. There is a great read at MQTT Essentials - All Core Concepts Explained talking about MQTT
  3. What arduino you are using?
  4. have you tried any of the MQTT examples that are provided with PubSubClient to see if they work?
  • Advice by @Colin copied from another thread"
There is one thing missing from that tutorial. With the latest mosquitto, if you want to access the broker across the network, you need to add some configuration. This is best done by making a file in /etc/mosquitto/conf.d/ with the configuration in. It can be called anything.conf. So make a file called, for example, /etc/mosquitto/conf.d/mossy.conf and in there put
listener 1883
allow_anonymous true
Hey there. Really appreciate your response.
  1. I will check out mosquitto. I had read up on it original couldn't get it connected on node-red.
  2. I'll look into that aswell
  3. Arduino Nano rp2040
  4. I've built this off the examples
And I should have said to restart mosquitto or reboot.
