Bonjour à tous
j'ai ce code qui me permet de d'activée le relai n°2 de la carte denkovi
I have this code that allows me to activate relay No. 2 on the map
https://denkovi.com/daenetip2-v2-snmp-ethernet-controller-with-24-digital-analog-io
mai voila mon problème est que je n'arrive pas a réalisée un AUTO OFF après 2 secondes
this may be my problem is that I can not achieve ** AUTO OFF ** after 2 seconds
code:
[{"id":"e3b16ff2.eeb65","type":"function","z":"3705ff16.53319","name":"","func":"flow.set("tmpVar", 0);\nvar password = flow.get("password");\nvar ip = flow.get("ip");\nvar port = flow.get("port");\nif(password === "" || ip === "" || port === "")\n msg.payload = "Please check fields!";\nelse \n msg.payload = "Connecting...";\nflow.set("host", ip + ":" + port);\nmsg.host = flow.get("host");\nmsg.community = flow.get("password");\nmsg.oid = "1.3.6.1.4.1.42505.9.2.1.1.0";\nreturn msg;","outputs":1,"noerr":0,"x":504.58338928222656,"y":270.25000762939453,"wires":[["58130c58.f3c444","1cc0ec85.331673"]]},{"id":"bd56479b.866598","type":"ui_button","z":"3705ff16.53319","name":"","group":"d2d6fe5d.5694b","order":5,"width":0,"height":0,"passthru":false,"label":"Refresh","tooltip":"","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":332.58338928222656,"y":271.25000762939453,"wires":[["e3b16ff2.eeb65"]]},{"id":"1cc0ec85.331673","type":"ui_text","z":"3705ff16.53319","group":"d2d6fe5d.5694b","order":1,"width":0,"height":0,"name":"","label":"STATUS","format":"{{msg.payload}}","layout":"row-spread","x":1055.5833892822266,"y":111.25000762939453,"wires":},{"id":"ca5de4d7.cbe018","type":"ui_text_input","z":"3705ff16.53319","name":"","label":"Community","tooltip":"","group":"d2d6fe5d.5694b","order":4,"width":0,"height":0,"passthru":true,"mode":"password","delay":300,"topic":"","x":352.58338928222656,"y":128.25000762939453,"wires":[["a914a0ff.6a73"]]},{"id":"a914a0ff.6a73","type":"function","z":"3705ff16.53319","name":"","func":"flow.set("password", msg.payload);\nif(msg.payload === "")\n msg.payload = "Please PASS";\nelse \n msg.payload = "";\nreturn msg;","outputs":1,"noerr":0,"x":503.58338928222656,"y":128.25000762939453,"wires":[["1cc0ec85.331673"]]},{"id":"48f94df6.12eeb4","type":"ui_text_input","z":"3705ff16.53319","name":"","label":"IP","group":"d2d6fe5d.5694b","order":2,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":334.58338928222656,"y":179.25000762939453,"wires":[["3b7eb6b0.1bc6ca"]]},{"id":"3b7eb6b0.1bc6ca","type":"function","z":"3705ff16.53319","name":"","func":"flow.set("ip", msg.payload);\nif(msg.payload === "")\n msg.payload = "Please enter valid IP!";\nelse \n msg.payload = "";\nreturn msg;","outputs":1,"noerr":0,"x":505.58338928222656,"y":179.25000762939453,"wires":[["1cc0ec85.331673"]]},{"id":"d5e2674c.f56948","type":"ui_text_input","z":"3705ff16.53319","name":"","label":"Port","group":"d2d6fe5d.5694b","order":3,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":334.58338928222656,"y":228.25000762939453,"wires":[["4f30cb44.09aae4"]]},{"id":"4f30cb44.09aae4","type":"function","z":"3705ff16.53319","name":"","func":"flow.set("port", msg.payload);\nif(msg.payload === "")\n msg.payload = "Please enter valid port!";\nelse \n msg.payload = "";\nreturn msg;","outputs":1,"noerr":0,"x":505.58338928222656,"y":228.25000762939453,"wires":[["1cc0ec85.331673"]]},{"id":"3198ed57.627f52","type":"function","z":"3705ff16.53319","name":"checkResponse","func":"\nif(msg.oid === "1.3.6.1.4.1.42505.9.2.1.1.0"){\nflow.set("updatingNow1", true);\n}\nif(msg.oid === "1.3.6.1.4.1.42505.9.2.2.1.0"){\nflow.set("updatingNow2", true);\n}\n\nreturn;","outputs":1,"noerr":0,"x":874.5833892822266,"y":255.25000762939453,"wires":[["1cc0ec85.331673"]]},{"id":"5ff4e536.21133c","type":"function","z":"3705ff16.53319","name":"module","func":"var password = flow.get("password");\nvar ip = flow.get("ip");\nvar port = flow.get("port");\nif(password === "" || ip === "" || port === "")\n msg.payload = "Please check fields!";\nelse \n msg.payload = "Connecting...";\nflow.set("host", ip + ":" + port);\nmsg.host = flow.get("host");\nmsg.community = flow.get("password");\nmsg.oid = "1.3.6.1.4.1.42505.9.2.2.1.0";\nreturn msg;","outputs":1,"noerr":0,"x":419.58338928222656,"y":574.2500076293945,"wires":[["f436c60.e5d0c38"]]},{"id":"78aafa58.0b77e4","type":"delay","z":"3705ff16.53319","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":507.58338928222656,"y":403.25000762939453,"wires":[["5ff4e536.21133c"]]},{"id":"58130c58.f3c444","type":"snmp","z":"3705ff16.53319","host":"","community":"","version":"1","oids":"","timeout":5,"name":"Get Port 3.1","x":740.5833892822266,"y":325.25000762939453,"wires":[["3198ed57.627f52","78aafa58.0b77e4"]]},{"id":"f436c60.e5d0c38","type":"snmp","z":"3705ff16.53319","host":"","community":"","version":"1","oids":"","timeout":5,"name":"Get Port 5.2","x":592.5833892822266,"y":574.2500076293945,"wires":[["f7aceb4f.471a08"]]},{"id":"1671ec83.2cdc63","type":"snmp set","z":"3705ff16.53319","host":"","community":"","version":"1","varbinds":"","timeout":"2","name":"Set Relay","x":1427.833396911621,"y":616.2500095367432,"wires":},{"id":"46424cbf.9b3fa4","type":"ui_switch","z":"3705ff16.53319","name":"","label":"Action AUTO OFF after 2 second","tooltip":"","group":"d2d6fe5d.5694b","order":7,"width":"0","height":"0","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"53=ON","onvalueType":"str","onicon":"","oncolor":"","offvalue":"53=OFF","offvalueType":"str","officon":"","offcolor":"","x":1129.0833892822266,"y":608.2500076293945,"wires":[["f1b8c46b.f24b48"]]},{"id":"f7aceb4f.471a08","type":"function","z":"3705ff16.53319","name":"Port 3","func":"var tmp = (flow.get("tmpVar")) + 1;\nflow.set("tmpVar", tmp);\n\nvar p53 = {payload:msg.payload.value === 0 ? "53=OFF" : "53=ON"}\n\nreturn [p53];","outputs":1,"noerr":0,"x":826.0833892822266,"y":607.2500076293945,"wires":[["46424cbf.9b3fa4"]]},{"id":"f1b8c46b.f24b48","type":"function","z":"3705ff16.53319","name":"Port 3","func":"if(flow.get("updatingNow1") === true) {\n flow.set("updatingNow1",false);\n return;\n}\nif(flow.get("updatingNow2") === true) {\n flow.set("updatingNow2",false);\n return;\n}\n\n\nmsg.host = flow.get("host");\nmsg.community = flow.get("password");\nmsg.varbinds = [\n {\n "oid": msg.payload.indexOf("53") != -1 ? "1.3.6.1.4.1.42505.9.2.2.3.0" : "1.3.6.1.4.1.42505.9.2.2.3.0",\n "type": "Integer",\n "value": msg.payload.indexOf("ON") != -1 ? 1 : 0\n }\n\n\n\n]\n\nreturn msg;","outputs":1,"noerr":0,"x":1350.0833930969238,"y":536.7500085830688,"wires":[["1671ec83.2cdc63"]]},{"id":"f9cce91.87c5218","type":"debug","z":"3705ff16.53319","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":754.0833892822266,"y":69.25000762939453,"wires":},{"id":"c7322c02.0620f","type":"ui_text_input","z":"3705ff16.53319","name":"","label":"PORTAIL N° 1 GEDICO","tooltip":"","group":"d2d6fe5d.5694b","order":6,"width":"0","height":"0","passthru":true,"mode":"text","delay":300,"topic":"","x":1126.1112213134766,"y":557.0833215713501,"wires":[]},{"id":"d2d6fe5d.5694b","type":"ui_group","z":"","name":"I/O","tab":"19a6e833.1c3e48","disp":true,"width":"6","collapse":true},{"id":"19a6e833.1c3e48","type":"ui_tab","z":"","name":"Denkovi Dashboard","icon":"standby","disabled":false,"hidden":false}]
