could someone tell me why Boolean Logic Ultimate receive only 1 Topic?
Add a debug node showing what is coming out of the intermediate nodes when you click the inject and check that the topics are different.
Set the debug nodes to Show Complete Message to make it easier to see what is there.
I want to do following:
call action if power is between 1-3 watt
that´s all
but i´m a newbie
the Inject´s 0, 2 and 10 sould simulate (just to Test) the Power which i read from Wall Switch later
It says that 1 out of 2 TOPICS arrived.
So I think the topics in kalibrierung 1 or 2 don't match the topics set in boolean logic.
Post you code so we can test.
As I understand it you have a value in msg.payload and if that is between 1 and 3 then you want to send a message on, but otherwise don't send anything? If so then you can do that with a Switch node configured as below. If the value is between 1 and 3 it sends the message to output 1 (in fact the only output as this one is configured) otherwise it does nothing.
here´s the code
[{"id":"5024232.88595dc","type":"tab","label":"Waschmaschine Status","disabled":false,"info":""},{"id":"891b4301.a2fc5","type":"server-state-changed","z":"5024232.88595dc","name":"watt auslesen","server":"63bce175.9acd","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.switch_waschmaschine_energy_power","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"x":230,"y":700,"wires":[[]]},{"id":"3e764739.6a5898","type":"combine-bangbang","z":"5024232.88595dc","upper":"0.6","lower":"0.5","invert":false,"name":"kalibrierung 1","x":280,"y":120,"wires":[["44378067.4a2bf","ca3fd02a.f481a"]]},{"id":"80735402.e5e828","type":"stoptimer","z":"5024232.88595dc","duration":"10","units":"Second","payloadtype":"num","payloadval":"0","name":"","x":450,"y":420,"wires":[["daf7fc1d.b37ae"],[]]},{"id":"ab34d74d.4fe758","type":"api-call-service","z":"5024232.88595dc","name":"led an","server":"63bce175.9acd","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_on","entityId":"sensor.switch_waschmaschine_status","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":910,"y":360,"wires":[[]]},{"id":"daf7fc1d.b37ae","type":"switch","z":"5024232.88595dc","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":670,"y":420,"wires":[["ab34d74d.4fe758"],["e22d6e9b.c0a04"]]},{"id":"e22d6e9b.c0a04","type":"api-call-service","z":"5024232.88595dc","name":"led aus","server":"63bce175.9acd","version":1,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"sensor.switch_waschmaschine_status","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":920,"y":460,"wires":[[]]},{"id":"3cc64077.48fa7","type":"combine-bangbang","z":"5024232.88595dc","upper":"3","lower":"2.9","invert":true,"name":"kalibrierung 2","x":280,"y":200,"wires":[["44378067.4a2bf","a233b49d.d941e8"]]},{"id":"e036939.fb62d7","type":"inject","z":"5024232.88595dc","name":"","topic":"","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":160,"wires":[["3e764739.6a5898","3cc64077.48fa7"]]},{"id":"6fdd833b.8d568c","type":"inject","z":"5024232.88595dc","name":"","topic":"","payload":"2","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":220,"wires":[["3e764739.6a5898","3cc64077.48fa7"]]},{"id":"d30878b5.a80638","type":"inject","z":"5024232.88595dc","name":"","topic":"","payload":"10","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":280,"wires":[["3e764739.6a5898","3cc64077.48fa7"]]},{"id":"29ee64e9.4d19cc","type":"debug","z":"5024232.88595dc","name":"output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":690,"y":140,"wires":[]},{"id":"44378067.4a2bf","type":"BooleanLogicUltimate","z":"5024232.88595dc","name":"","filtertrue":"both","persist":true,"sInitializeWith":"WaitForPayload","triggertopic":"trigger","outputtriggeredby":"all","inputCount":2,"topic":"result","x":480,"y":160,"wires":[["29ee64e9.4d19cc"],[],[]]},{"id":"ca3fd02a.f481a","type":"debug","z":"5024232.88595dc","name":"kalibrierung 1","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":470,"y":80,"wires":[]},{"id":"a233b49d.d941e8","type":"debug","z":"5024232.88595dc","name":"kalibrierung 2","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","x":470,"y":280,"wires":[]},{"id":"63bce175.9acd","type":"server","z":"","name":"Home Assistant","addon":true}]
yes, but is it possible to call action 1 if value is between 0.5 and 3
and call action 2 if else ?
i think i done it
[{"id":"6693685b.6ad928","type":"stoptimer","z":"5024232.88595dc","duration":"1","units":"Minute","payloadtype":"num","payloadval":"0","name":"","x":340,"y":200,"wires":[["9cbd3876.19f9e8"],[]]}]
Did you look at my example with the Switch node? What you want can easily be done using that.
