Browser lock up
Just had by browser tab freeze when selecting nodes inside a group (1.1.0)
Other NR tabs still worked - went back to original tab (browsing my Win10 instance) and had this which I've not ever had before on NR
Waited/refreshed/waited eventually gave up and restarted NR
All seemed to be OK again but then after editing inside the same group ( bottom one) - when I went to select another group (top one) - the first one stayed with dotted visual outline
No errors showing in console
Going to close/reopen whole browser and see if it happens again
Try clearing the cache too.
I'm getting this tab lockup with node-red V1.1.0 (certain i didnt get it pre V1.1.0)
If tab is left open for any amount of time (cant put a number on it yet but somewhere between 10m ~ 1h) it becomes unresponsive.
Cant get into console to see any issues - only recourse is a refresh or close / re-open.
EDIT...
FWIW - I am not using groups FWIW
Please try with 1.1.1 - no need for any more "me too" replies if you're on 1.1.0.
This was reported on the issue list and some potential fixes went in 1.1.1 - but as I couldn't reproduce, the fixes are somewhat speculative.
That said, the early response on the issue suggests it has had a positive effect.
I have seen this in 1.1.1
My observations, not fact!
My main system is on an RPi3, I use a development installation on the laptop I am surfing from.
I have a 'feeling' (not confirmed yet) that if I am doing something on the main system, leave Firefox 78.0.1 tab open, go over development system and spend some time there while developing a flow, then return to main system, the page is non responsive. If I close tab, open a new tab, all is well.
I say 'feeling', I spent years looking for patterns with faults and after this happening several times, this morning I kind of sensed that it only happened when I went to the development server. Can't say for certain I have noticed that if I leave the tab and come back to it with general browsing all is OK.
I will keep and eye on it to see if I get any other situations that cause it.
Don't know if this helps...
Nothing misbehaved yesterday, but, my experience this morning
Production machine running OK
Started Node RED on laptop
(From Web Developer Console)
Access localhost:1880/ui, Welcome screen displays (Cache?)
Rendered http://localhost:1880/ui/css/app.min.less successfully. app.min.js:532:12831
CSS for http://localhost:1880/ui/css/app.min.less generated in 216ms app.min.js:532:12831
Less has finished. CSS generated in 216ms app.min.js:532:12831
You are using the ngTouch module.
AngularJS Material already has mobile click, tap, and swipe support...
ngTouch is not supported with AngularJS Material! app.min.js:148:303
Source map error: Error: request failed with status 404
Resource URL: http://localhost:1880/ui/js/app.min.js
Source Map URL: angular-chart.min.js.map
CTRL-F5,
refresh screen
CTRL-R
CSS for http://localhost:1880/ui/css/app.min.less generated in 311ms app.min.js:532:12831
Less has finished. CSS generated in 311ms app.min.js:532:12831
Clear Data (Cache)
Same messages as above
Close tab, open new tab
All OK
10 Jul 06:28:21 - [info] Node-RED version: v1.1.1
10 Jul 06:28:21 - [info] Node.js version: v12.18.2
10 Jul 06:28:21 - [info] Linux 5.3.0-62-generic x64 LE
10 Jul 06:28:21 - [info] Loading palette nodes
10 Jul 06:28:22 - [info] Dashboard version 2.22.1 started at /ui
10 Jul 06:28:22 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
Dell M6700 Laptop
Ubuntu 18.04LTS
Firefox 78.0.1
