Bug when adding Spacer Dashboard 2
OS Red Hat Enterprise Linux release 9.4 (Plow)
Node-Red Version 4.0.8
Dashboard
Issue
Can't set Group when Adding a spacer from layout
Spacer doesn't appear in the group I tried to add it to
Shows up as invalid in Config menu
If I edit it here I can select the group and set it's dimensions
And now its appears under layout as expected
This was definitely working in a previous release
Anyone else seeing this issue
regards Gerry
What version of node-red are you running?
There were changes in this area in latest node-red V4.0.8
Node-Red Version 4.0.8.
Just confirmed that this works correctly in v4.0.7
So bug introduced in v4.0.8
It's not NR core, it's the v1.21.0 of Dashboard.
Will fix that
Oops you're correct. Just updated dashboard to v1.21.0 on my laptop and the bug is there
