Can not edit/write text
Hello
i can not write to text editor. Nothing
Why?
Could you explain a bit more? What text editor?
Are you saying you can't enter anything in the function node?
are any other nodes giving you problems?
what version of NR and node.js are you running?
what platform and OS are you running NR on?
I see you are using Home Assistant, you might want to ask on their forum.
Uploading: IMG_20221107_225919.png...
I have problem with write to this. All is work only this editor no. In all nodes where is this editor/listbox i can not write
Hi @LukasSmolarik
have a read of this post and see if you have any of the listed nodes installed:
