Configuring FINS NODE
Hi. I am trying to get data from OMRON NX1P2 using FINS node. !st of all thanks for developing the nodes.
I am new to node-red. i have problems configuring the FINS node. Any help or probably an example or two that i can refer to.
Thanks in advance
Seeing that not too many people have used that node, you might want to contact the author on the GitHub page https://github.com/Steve-Mcl/node-red-contrib-omron-fins/issues
ok. thanks for the links.
What's your problem?
Do you know how to setup FINS on an OMRON PLC?
Also, did you spot the built in help info describing what to enter in the DA and SA fields?
Lastly I helped another user get going in this thread - have a read of that - it might help?
Either way, let us know how you get on.
