Hi everyone,
Many of us run Node-RED on a Raspberry Pi for IoT projects, home automation, or industrial monitoring. While the web-based Dashboard is great, having a dedicated local touchscreen can make the system much more practical — especially for wall-mounted panels, control kiosks, or 24/7 operator interfaces.
One of the cleanest solutions is using a DSI display directly connected to the Raspberry Pi. It offers better performance, lower power consumption, and a tidier setup compared to HDMI.
I wanted to share a comprehensive technical guide that walks through the entire process:
Why DSI is preferred over HDMI for embedded/Node-RED projects
Hardware requirements and DSI cable connection (including polarity and locking)
Step-by-step software configuration (raspi-config, config.txt, dtoverlay, resolution settings)
Touch screen setup and calibration
Advanced optimizations (GPU memory, hardware acceleration, multiple displays on Pi 5)
Common troubleshooting (black screen, wrong resolution, touch not working, flickering, etc.)
Best practices for reliable industrial/continuous operation
Here is the full detailed guide:
How to Connect Raspberry Pi to a DSI Display
It’s written from a practical embedded perspective and should be very useful for anyone building a local touchscreen interface for Node-RED (whether using the standard Dashboard, ui-dashboard, or custom setups).
