I've run into this error with the MS SQL database node: ConnectionError: Failed to connect to (IP Address) in 5000ms, it was working fine before but after a recent power outage this error comes up every time I try to run it. I am working on a mini PC using remote device control, and is running Ubuntu 20.X.
I'm sorry that there isn't much information here, but I'm not sure how much of it I can share since I am making this for another company.
Thanks for your answer,
The IP of the mini PC not changed however I don't that I have the access needed to check the IP of the SQL server, would I need to run a query in the MS database engine to find it?
