Hello there,
Using the node-red-contrib-ui-upload (node) - Node-RED causes my dashboard to unexpected behaviour: once I put the node in the editor, the dashboard becomes with default theme even if unselected or changed color in the editor, and also any new node put in the flow won't appear (just the tables of the ui-table):
before:
after:
If I remove the upload node from the editor the dashboard remains corrupted, when I restart Node-red it fixes until I put again the ulpoad node (that obvioysly I need).
"id": "663ef125791e8be8",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "175d72fc57f2089e",
"type": "ui_tab",
"name": "Home",
"icon": "dashboard",
"disabled": false,
"hidden": false
"id": "26c7e2e16ee849c6",
"type": "ui_base",
"theme": {
"name": "theme-dark",
"lightTheme": {
"default": "#0094CE",
"baseColor": "#0094CE",
"baseFont": "-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif",
"edited": false
"darkTheme": {
"default": "#097479",
"baseColor": "#097479",
"edited": true,
"reset": false
"customTheme": {
"name": "Untitled Theme 1",
"default": "#4B7930",
"baseColor": "#4B7930",
"themeState": {
"base-color": {
"value": "#097479",
"edited": false
"page-titlebar-backgroundColor": {
"value": "#097479",
"edited": false
"page-backgroundColor": {
"value": "#111111",
"edited": false
"page-sidebar-backgroundColor": {
"value": "#333333",
"edited": false
"group-textColor": {
"value": "#0eb8c0",
"edited": false
"group-borderColor": {
"value": "#555555",
"edited": false
"group-backgroundColor": {
"value": "#333333",
"edited": false
"widget-textColor": {
"value": "#eeeeee",
"edited": false
"widget-backgroundColor": {
"value": "#097479",
"edited": false
"widget-borderColor": {
"value": "#333333",
"edited": false
"base-font": {
"value": "-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"
"angularTheme": {
"primary": "indigo",
"accents": "blue",
"warn": "red",
"background": "grey",
"palette": "light"
"site": {
"name": "Node-RED Dashboard",
"hideToolbar": "false",
"allowSwipe": "false",
"lockMenu": "false",
"allowTempTheme": "true",
"dateFormat": "DD/MM/YYYY",
"sizes": {
"sx": 48,
"sy": 48,
"gx": 6,
"gy": 6,
"cx": 6,
"cy": 6,
"px": 0,
"py": 0
"id": "ab67ea46c7860390",
"type": "ui_group",
"name": "Default",
"tab": "175d72fc57f2089e",
"order": 1,
"disp": true,
"width": "6",
"collapse": false,
"className": ""
"id": "1a8aa824bdf29c9e",
"type": "ui_button",
"z": "663ef125791e8be8",
"group": "ab67ea46c7860390",
"order": 0,
"width": 0,
"height": 0,
"passthru": false,
"label": "button",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "",
"payload": "",
"payloadType": "str",
"topic": "topic",
"topicType": "msg",
"x": 170,
"y": 120,
"id": "93ea5a940edcf969",
"type": "ui_upload",
"title": "upload",
"accept": "",
"order": 1,
"width": 0,
"height": 5,
"chunk": 256,
"transfer": "binary",
"x": 170,
"y": 80,
Also, I don't know why, it seems that the node is customized (it's in Italian as you can see), different from the example like here: https://flows.nodered.org/flow/687918dd5cb66a3bfc2a661e15ef4237
I'm using a fresh new installation of node-red 3.1.0, but using 18.18.2.
Any suggestions?
Thanks in advance
EDIT: Here the log, nothing relevant to me:
15 Nov 10:46:18 - [info]
Welcome to Node-RED
15 Nov 10:46:18 - [info] Node-RED version: v3.1.0
15 Nov 10:46:18 - [info] Node.js version: v18.18.2
15 Nov 10:46:18 - [info] Windows_NT 10.0.19044 x64 LE
15 Nov 10:46:18 - [info] Loading palette nodes
15 Nov 10:46:20 - [info] Dashboard version 3.6.1 started at /ui
15 Nov 10:46:20 - [info] Settings file : c:\Users\xxx\.node-red\settings.js
15 Nov 10:46:20 - [info] Context store : 'default' [module=memory]
15 Nov 10:46:20 - [info] User directory : c:\Users\xxx\.node-red
15 Nov 10:46:20 - [info] Projects directory: c:\Users\xxx\.node-red\projects
15 Nov 10:46:20 - [info] Server now running at http://127.0.0.1:1880/
15 Nov 10:46:20 - [info] Active project : xxx
15 Nov 10:46:20 - [info] Flows file : c:\Users\xxx\.node-red\projects\xxx\flows-REC.json
15 Nov 10:46:20 - [info] Starting flows
15 Nov 10:46:20 - [info] Started flows
15 Nov 10:48:08 - [info] Stopping flows
15 Nov 10:48:08 - [info] Stopped flows
15 Nov 10:48:08 - [info] Updated flows
15 Nov 10:48:08 - [info] Starting flows
15 Nov 10:48:08 - [info] Dashboard version 3.6.1 started at /ui
15 Nov 10:48:08 - [info] Started flows
15 Nov 10:57:56 - [info] Stopping flows
15 Nov 10:57:56 - [info] Stopped flows
15 Nov 10:57:56 - [info] Updated flows
15 Nov 10:57:56 - [info] Starting flows
15 Nov 10:57:56 - [info] Started flows
