Hello. anyone communicated a CP1L-E with red nodes? i try with ethernet ip and it does not work.
What protocols is it supposed to support and what did you try?
ethernet ip with what I found I do not go, it's for bechoff.
I don't know what bechof is. If you don't know what protocol it supports and no-one has already done it then it will be difficult to make progress. Don't they publish the protocols it supports? Modbus or something.
Isn't the CP1L-E an OMRON plc?
One of the protocols most OMRON PLCs use is FINS. A relatively basic UDP / TCP protocol with publicly published documentation that you could use to write a node for node-red.
