Create a table in .csv or.txt from a node template
Hi everyone,
[{"id":"ab3ee0589c3e8b29","type":"ui_template","z":"9d82413d96f85954","group":"21bd4d782123bfb3","name":"funciona_perfecto_v3_registry","order":3,"width":8,"height":10,"format":"<p><strong>Report log:</strong></p>\n<table style=\"border-collapse: collapse; font-size: 13px; font-weight: bold ;margin-top: 20px; height: 1000px;\" border=\"1\">\n  <tbody>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>PRODUCT NAME</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.productName}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>PRODUCT NUMBER</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.productNumber}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>DATE</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.date}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>START TIME</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.startTime}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>END TIME</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.endTime}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>CYCLE TIME</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.cycleTime}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>PAUSE TIME</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.pauseTime}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>TANK 1 TOTAL</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.tank1Total}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>TANK 2 TOTAL</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.tank2Total}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>MINIMUM AIR TEMPERATURE</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.minAirTemperature}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>MEDIUM AIR TEMPERATURE</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.mediumAirTemperature}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>MAXIMUM AIR TEMPERATURE</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.maxAirTemperature}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>MINIMUM FLOW</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.minFlow}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>MEDIUM FLOW</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.mediumFlow}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>MAXIMUM FLOW</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.maxFlow}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>MINIMUM HUMIDITY</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.minHumidity}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>MEDIUM HUMIDITY</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.mediumHumidity}}</td>\n    </tr>\n    <tr>\n      <td style=\"white-space: nowrap;\"><p><strong>MAXIMUM HUMIDITY</strong></p></td>\n      <td style=\"white-space: nowrap;\">{{msg.maxHumidity}}</td>\n    </tr>\n  </tbody>\n</table>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":790,"y":160,"wires":[[]]},{"id":"21bd4d782123bfb3","type":"ui_group","name":"registry","tab":"ab1ada9da2ce8e76","order":1,"disp":false,"width":"25","collapse":false,"className":""},{"id":"ab1ada9da2ce8e76","type":"ui_tab","name":"REGISTRY","icon":"dashboard","order":13,"disabled":false,"hidden":true}]
How can I make with this node the same table in .csv or .txt in a folder inside the iot, I use the WinSCP program.
Thank you very much!
This is a duplicate topic, please do not double post. Create .CSV and .txt from a table
If you are not getting replies on OG topic, try adding more info and a better description of your issue.
