Creating custom node breaks ui_button
Hi! I have an issue - whenever I add a custom node to my node-red, the ui_buttons that I have on my dashboard lose their input "port". Trying to deploy the flows would yield that those elements are not properly configured.
At first I thought -- fair enough, I probably broke it somehow with my custom code, but now I have cut my custom object down to the lower-case example component and the same thing still happens.
How to debug? Thanks for hints! :pray:
Please check both the Node-RED log and your browser console for any errors and let us know.
This kind of thing can happen due to poorly isolated code in a node - I know because I've done it myself!
These days, I try to remember to wrap my code in an IIFE:
;(function () { // Isolate the front-end code
    'use strict'
    RED.nodes.registerType('moment',{
    }); // ---- end of RED.nodes.registerType ---- //
</script>
Thanks for the hint and sorry for the late reply!
Finally digged into making it work today, and although it took me way too long trial-and-error, I finally figured out that it somehow was caused by having node-red-dashboard as well as node-red-contrib-ui both installed (both register ui_button component).
I am not sure how exactly my custom component broke it, but once I finally removed node-red-contrib-ui, everything started to work as expected :tada:
