ui_table as many other contrib-ui nodes use theme related API-s when initializing and which again related to existence and readyness of ui_base. So the outcome may be pretty same. I see fixes in ui_table which should avoid the issue. Not sure if really fixed ...No time to investigate right now..
Hi @hotNipi,
I am new to Node-red and trying to use the chart node from Github documentation. But I face the same error.
And the function node contains the following code.
But the chart on the dashboard is empty.
Could you please explain a little more, how to fix the problem and where I should configure the ui_base and theme state?
Thanks in advance!
Regards,
Devi
What is the version of the dashboard?
2.26.0: Milestone Release has fix for the situation. So do update the dashboard and do not forget to flush browser cache after updating.
Ok! Thanks for the prompt reply!
It works! Thank you so much!
