While playing with an entirely different thing on the RPI, I went to the Dashboard.
This is not right.
There seems to be "empty lines" in the display.
See attached.
The big red rectangle. It isn't supposed to be there.
I haven't edited the flow.
It is password protected - but that's just me being silly mentioning it.
I do notice that dashboard edit has slightly changed.
I now have a +spacer in the group list which wasn't there before, AFAIK.
(UPDATE!)
Seems the "Text formatting" and "Picture" nodes are causing it.
(See second picture)
Oh, and I know they are now not in the same group.
For the sake of trying, I relocated them from the "indicators" group and put them in the "index" group.
Deployed and now the problem has followed them two nodes.
Yeah, ok. I am not sure which one is doing it.... But: hey I am trying to work it out.
Of course this raises the question:
It didin't used to do this. I haven't changed anything.
Why is it suddenly doing it?
(Third picture is dashboard after moving the two nodes)
And this is the code in the two nodes:
[{"id":"b0ae18a6.6763d8","type":"ui_template","z":"381d953d.4cf092","group":"145609.3ad979f8","name":"Picture","order":1,"width":0,"height":0,"format":"<style>\n body {\n background-image: url(\"/Pictures/Levers_Switches.jpg\");\n background-size: cover;\n }\n #Master_Control_Buttons {\n background-image: url(\"/Pictures/metal_7.jpg\");\n }\n #Master_Control_Load {\n background-image: url(\"/Pictures/metal_7.jpg\");\n }\n</style>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":830,"y":210,"wires":[["7de5fab2.7b50b4"]]},{"id":"c4474899.f269d8","type":"ui_template","z":"381d953d.4cf092","group":"145609.3ad979f8","name":"Text formatting","order":2,"width":0,"height":0,"format":" <style>\n .nr-dashboard-cardtitle {\n text-align:center;\n }\n</style>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1130,"y":210,"wires":[["a6570e08.62d4b"]]},{"id":"145609.3ad979f8","type":"ui_group","z":"","name":"Index","tab":"3776e46e.a7d894","order":1,"disp":false,"width":"3","collapse":false},{"id":"3776e46e.a7d894","type":"ui_tab","z":"","name":"Master Control","icon":"dashboard","order":5}]
