@Paul-Reed he's running on the cloud....
Not wanting to confuse anyone further:
May I suggest you remove the other dashboard and only use the one I suggested.
When I was starting out with Node-Red I did what you did and caused myself no end of problems.
I am not saying anything against the other dashboard. I am only speaking of what happened to me.
Yes, it will need a bit of work to then go around and re-assign the existing ones with the newer ones.
But that is little effort compared to what you may find if you continue to use the other one.
Yes, I get that. I'm running node-RED in a Oracle cloud instance, but I still have a CLI interface, where I can see the node-red-log.
Is a bluemix cloud VM different to a Oracle cloud VM?
