Double click on node, doesn't work
example_flow.json (3.9 KB)
I have imported this flow (from another node-red) and after I deploy it, unable to double click on the nodes. Even if I drag another node, that also doesn't work. This Node-red is running in a docker container and it shows that the docker container is healthy.
Can you check the browser's JavaScript console for any error messages when you double click on the node?
