Email sender name
I use node-red-node-email to send emails. Is it possible to change the sender name? The emails I got has only the adress as sender. But I want to add a name there. It should looks like:
Node-RED (xyz@gmail.com)
I use gmail with 2 factor authentification.
Thanks in advance
Markus
The from property has to be valid email format.
You could try
Node-Red<xyz@gmail.com> as the from address then the email client may display the name Node-Red
No that doesn't work.
But I found a solution. The userid is the gmail address. I combined the the email node with a change node. I added msg.from = Node-RED:xyz@gmail.com. (xyz@gmail.com is your email address)
