Error Cannot Get /ui when launching the Dashboard on my PC
First off I am very new at this. So please be kind. I had Node Red running on a Raspberry Pi and had a isssue so I did a clean install of the PI and Node Red. After that when I tried to launch the Node Red dashboard from my home PC like before I get the error Cannot GET /ui. I can get on XXX.XXX.XXX.XXX:1880 site.
I have spent hours searching for help online but nothing has helped.
Netstat
I am using version 2.2.0 of Node-Red
Are you just using /ui or 192.169.1.nn:1880/ui? (Where 192.168.1.nn is the IP address of NR
Also did you install the dashboard?
I am using 10.0.0.34:1880/ui.
I used this link for the installer bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered)
Have you installed the node-red-dashboard - node-red-dashboard (node) - Node-RED
and added some of the dashboard nodes to a flow?
If not, go to the palette, and you'll find it in the Install tab.
mydash
This is a screenshot of what I have. If I need to install the Node Red dashboard I do not know how to do that.
I did say...
Ok I did find out how to install the Node Red dashboard and successfully did that. It is working except when I a node tries to connect here is a screenshot
Paul when I went there nothing was there to choose from. Now there is. Do I need Mosquitto MQTT to make the node to connect.
I did say...
Are you still trying to get the dashboard working, or are you now trying to use mqtt? If you want to use mqtt then you need a broker such as mosquito.
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
Paul why do the payload settings keep reverting back to True and false when I try to set them to 1 and 0
As @Colin has said, you really need to spend a little time watching the Node-RED Essentials playlist to get a better understanding how node-RED works.
After that, if you have a problem, please start a new topic, and fully describe what the problem is, and what you have tried to solve it.
I did get the dashboard working. I just reinstalled it on the PI.
