I am trying to follow the instruction from https://www.hackster.io/rei-vilo/sensortag-to-blynk-using-node-red-f90c4d
but the raspberry pi cannot detect the sensortag after node-red-start. I guess it is related to the following warning, how can I fix this? Please help! thank you
Welcome to Node-RED
23 Dec 10:41:09 - [info] Node-RED version: v0.19.4
23 Dec 10:41:09 - [info] Node.js version: v8.11.1
23 Dec 10:41:09 - [info] Linux 4.14.90+ arm LE
23 Dec 10:41:20 - [info] Loading palette nodes
23 Dec 10:41:38 - [warn] ------------------------------------------------------
23 Dec 10:41:38 - [warn] [node-red-node-sensortag/sensorTag] Error: Cannot find module '../build/Release/binding.node'
23 Dec 10:41:38 - [info] Settings file : /home/pi/.node-red/settings.js
23 Dec 10:41:38 - [info] Context store : 'default' [module=memory]
23 Dec 10:41:38 - [info] User directory : /home/pi/.node-red
23 Dec 10:41:38 - [warn] Projects disabled : editorTheme.projects.enabled=false
23 Dec 10:41:38 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
23 Dec 10:41:38 - [info] Creating new flow file
your credentials.
23 Dec 10:41:38 - [info] Starting flows
23 Dec 10:41:38 - [info] Started flows
23 Dec 10:41:38 - [info] Server now running at http://127.0.0.1:1880/
