Error with Rbe after NR update 2.0.6 -> 2.1.2 / NodeJS 10.x -> 14.x
I ve got this error after update 2.1.2 and no idea where I use it and its not removable or should I try removal by console ?
thx!
The RBE node was brought into the core of Node-RED 2.x and relabelled the Filter node.
This makes the node-red-node-rbe module redundant when running Node-RED 2.x or later.
That error is harmless (and a sign things are actually working properly). You can safely uninstall the RBE module - although how you do that will depend on how you installed Node-RED originally.
