Hi, I just stumbled over the fact that the RBE node has been replaced by the filter node in 2.1.x versions.
Now the thing is, I have a number of existing flows where I use the "good old RBE node" in many places. Should the migration from 1.x.y not have taken this into consideration, finding RBE in the flow and automatically replacing it with FILTER? Or is the "concept" that you are supposed to manually work through your flows and fix this?
The existing RBE node seems to keep working, but is it really? I see all the RBE nodes I added to my flows but it is not listed in the node column any longer. You can copy & paste a RBE node in use and create more from this copy but you cannot add it from the node list. All this just creates uncertainty and makes you really worry about it's functionality
Is there a simple method available to "upgrade" existing flows using RBE replacing them with FILTER??
