Failure(Bad value)
When i looked at the node red debug screen i saw the following:
Failure Bad Values
But i don't find from wich node the problem is coming. If i click on "node: 49611514.d5bd4c" i get directed to my configuration nodes but i can't find the correspondending configuration node it's referring to?
Like you can see in the picture above.
Can somebody help me where the alarm message is coming from?
Thanks at advance!
Kind regards,
Ward
What if you manually search for that node ID? Ctrl-f to open the search dialog, or use the search bar at the top of the info sidebar tab.
@knolleary it works with Ctrl-f and a manually search. It was a configuration node which i didn't name yet.
Thanks for the reply.
