Upon further reply I will remove HCI 0.1.5 Addon from the node-red pallet, but for now attempted with the prior images to show a message counts of has not changed. The count is not happening, like it does so easily with the ihost SonOff to NS Panel SonOff handling its native devices (supported).
Also with 1.1.1 addon the menus differ in functionality to 0.1.5.
If I blow away my /data or say my /node-red-data folder again , I will simply install 1.1.1 again but I am certain I will get that "connection closed (error) red icon again.
However this time (#6) will be the first attempt with a /node-red-data folder on the SD card. You taught me this !
I then can move on to the next red ![]()
Your flow credentials file is encrypted using a system-generated key.
If the system-generated key is lost for any reason, your credentials
file will not be recoverable, you will have to delete it and re-enter
your credentials.
You should set your own key using the 'credentialSecret' option in
your settings file. Node-RED will then re-encrypt your credentials
file using your chosen key the next time you deploy a change.
C-nP'd I am afraid I cannot change the color or realize why one font is larger that the other , weird ?
- ignore the 'node-red-contrib-flic-buttons-hci' nodes.
