I worked the whole day on a flow, it was 99% finished and now it's gone.
The tab in the editor where it was on is gone, the other tabs are still there.
Clicking on search flow and type in one of node names used will show the node, but clicking on it will not bring me to the flow.
Looking in the flowxxxxx.json with a text editor you can "see" that there is still something, functions etc that I made are there.
Tried to restore the .flowxxxx.json.backup file, but there's also the missing tab not available.
Anybody a hint/tip to get the tab with my flow back?
Have you got 2 flows files at different locations?
If you stop/start node-RED and look at the log, it will show you the location of the flows file that is being loaded.
Is the one that you mentioned above at the same location?
Meanwhile I got the missing tab back.
Started NR with a new flow Node-red Testflow
Copied everything from the flows_Desktop-Win10-64B.json file with a text editor.
In the new Testflow Import -> Clipboard.
Please note that by default the flows use the hostname of the computer. If for whatever reason the hostname of the flow changes, it will create a new flow with the new hostname by default. This can be "prevented" by starting node-red with the name of the flow. See the command-line help for the full command:
afelix@Hewlett:~/.node-red$ node-red --help
Node-RED v0.20.7
Usage: node-red [-v] [-?] [--settings settings.js] [--userDir DIR]
[--port PORT] [--title TITLE] [--safe] [flows.json]
Options:
-p, --port PORT port to listen on
-s, --settings FILE use specified settings file
--title TITLE process window title
-u, --userDir DIR use specified user directory
-v, --verbose enable verbose output
--safe enable safe mode
-?, --help show this help
Documentation can be found at http://nodered.org
