Flow section on this site. Unable to switch to previous or next page because of missing buttons
I'm not sure where to start this topic. As mentioned the are no longer next and prev(ious)-buttons to click on listed flows in the flows section.
I tried on fFirefox, Chrome and Opera.
Roland
Thanks for highlighting. I pushed some updates to the site this week (note the new layout) - looks like the buttons have decided they don't like the update.
I'll investigate
I also noted the filter resets for every search. It is a little annoying to reset it every time..
@gnome2012 now fixed!
@E1cid I'm not immediately able to reproduce what you describe. Could you describe a bit more what you're seeing?
On flow library search for say modbus, set filter as I am looking for a node.
Then i enter mqtt and hit enter the filter resets.
If i do not hit enter it stays, but hitting enter resets the filter.
Not a major issue but slightly annoying if i out of habit hit enter.
@knolleary there is another edge case that seems broken. When go to flow.nodered.org, I always click on my profile image and then my handle (gorenje):
That gets me to https://flows.nodered.org/user/gorenje which is empty:
It used to get me to https://flows.nodered.org/user/gregoriusrippenstein which is my npm handle (gorenje is my github handle):
There seems to be a mapping between github and npm handles which has disappeared (the workflow definitely worked before the redesign).
@E1cid understood; will figure out a fix
@gregorius thanks for highlighting; my github/npm usernames are the same, so my local test setup doesn't quite hit the same code paths as yours does. Will figure out what's happened.
That reminds me, my GH name has capital letters but NPM only allows lowercase letters so I have the same problem as Gerrit - my capitalized Page is empty. Thanks
@gregorius now fixed - thanks for highlighting
Yep works for me, cheers Nick!
