Get-history: Request failed with status code 400 when using Entity ID INCLUDE not IS
Hello, using Node-Red
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 14.1.5
You are running the latest version of this add-on.
System: Home Assistant OS 10.1 (amd64 / generic-x86-64)
Home Assistant Core: 2023.5.2
Home Assistant Supervisor: 2023.04.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
With Home Assistant Core 2023.5.2, the get history node using Entity ID INCLUDE has started returning "Request failed with status code 400"
I have used INCLUDE "binary_sensor._sensor_motion" as well as "device_tracker." which worked before 2023.5.2. Also Entity ID IS seems to work with no problem, just the INCLUDE.
Since this appears to be a HA related question, and very few here use HA you may be better asking on an HA forum.
Thank you for the response!
