I've installed Node-Red v2.0.3 on a VM in Oracle Cloud und manually Installed Git V2.x as described here ORACLE-BASE - Git 2.x Installation on Linux
When starting NR manually at bash everything is finde, the projects extension is working:
[opc@node-red ~]$ node-red
27 Jul 06:34:45 - [info]
Willkommen bei Node-RED!
27 Jul 06:34:45 - [info] Node-RED Version: v2.0.3
27 Jul 06:34:45 - [info] Node.js Version: v14.17.2
27 Jul 06:34:45 - [info] Linux 5.4.17-2102.202.5.el7uek.aarch64 arm64 LE
27 Jul 06:34:45 - [info] Paletten-Nodes werden geladen
node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
In the future, you will have to enable it yourself.
See https://github.com/yagop/node-telegram-bot-api/issues/319. internal/modules/cjs/loader.js:1085:14
27 Jul 06:34:46 - [info] Einstellungsdatei: /home/opc/.node-red/settings.js
27 Jul 06:34:46 - [info] Kontextspeicher: default [module=memory]
27 Jul 06:34:46 - [info] Benutzerverzeichnis: /home/opc/.node-red
27 Jul 06:34:46 - [info] Projektverzeichnis: /home/opc/.node-red/projects
27 Jul 06:34:46 - [info] Server wird jetzt auf http://127.0.0.1:1880/ ausgeführt
27 Jul 06:34:46 - [info] Aktives Projekt: wxbot
27 Jul 06:34:46 - [info] Flow-Datei: /home/opc/.node-red/projects/wxbot/flow.json
27 Jul 06:34:46 - [info] Flows werden gestartet
27 Jul 06:34:46 - [info] Flows sind gestartet
but when starting the nodered .service the project extension is deactivated because git is not found
[opc@node-red ~]$ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://10.0.0.122:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
27 Jul 06:37:53 - [info]
Welcome to Node-RED
27 Jul 06:37:53 - [info] Node-RED version: v2.0.3
27 Jul 06:37:53 - [info] Node.js version: v14.17.2
27 Jul 06:37:53 - [info] Linux 5.4.17-2102.202.5.el7uek.aarch64 arm64 LE
27 Jul 06:37:53 - [info] Loading palette nodes
Tue, 27 Jul 2021 06:37:54 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
See https://github.com/yagop/node-telegram-bot-api/issues/319. at internal/modules/cjs/loader.js:1085:14
27 Jul 06:37:54 - [info] Settings file : /home/opc/.node-red/settings.js
27 Jul 06:37:54 - [info] Context store : 'default' [module=memory]
27 Jul 06:37:54 - [info] User directory : /home/opc/.node-red
27 Jul 06:37:54 - [warn] Projects disabled : git command not found
27 Jul 06:37:54 - [info] Flows file : /home/opc/.node-red/flows.json
27 Jul 06:37:54 - [info] Creating new flow file
your credentials.
27 Jul 06:37:54 - [info] Server now running at http://127.0.0.1:1880/
27 Jul 06:37:54 - [info] Starting flows
27 Jul 06:37:54 - [info] Started flows
git v2.2.2 installed and working from the bash.
pls help I am not very skilled in linux...
Thanks!
