Git SSH-Key based authentication failes, if username contains "AT" character
I have a header based authentication and the username contains the "@" character.
After doing several debugging, it seems that the "@" char is the reason, which is used as name in the keyfile.
It seems, that the key file can't be found.
Storage is in
.node-red/projects/.sshkeys/<username>_keyname
Can you help me to fix this issue?
Sounds like there could be a bug. Can you raise an issue on GitHub so this can be investigated?
Thanks for your support, I opened Git SSH-Key based authentication failes, if username contains "AT" character Ā· Issue #3246 Ā· node-red/node-red Ā· GitHub
