I'm trying to use this node:
It looks like the project was going well enough but has been abandoned.
I installed it following the instructions on the github link. But it kind of broke my node-red install. Specifically, it deleted every connection line on every tab of my deployment. I deleted all my tabs and imported from a backup and everything still works.
The following nodes were added to my installation:
The only node I can drag to the tab is the "neviweb gateway" node. The others, nothing happens when I try to drag them in, they just don't appear. So here is the flow:
"id": "edc924a8.359d08",
"type": "inject",
"z": "2fce32f2.b86ece",
"name": "Home Mode",
"topic": "0",
"payload": "",
"payloadType": "date",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 270,
"y": 120,
"c3fee2c9.c3829"
"id": "32aabd15.04aee2",
"type": "inject",
"name": "Away Mode",
"topic": "2",
"payload": "",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 270,
"y": 180,
"c3fee2c9.c3829"
"id": "c3fee2c9.c3829",
"type": "change",
"rules": [
"t": "set",
"p": "gateway",
"pt": "msg",
"to": "11243",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 550,
"y": 140,
"id"
"id": "id",
"type": "neviweb-gateway",
"account": "f862a862.af3dd8",
"mode": "SET",
"info": "payload",
"x": 810,
"y": 140,
"a11a8fd6.076ff"
"4064ca0.8313238"
"id": "a11a8fd6.076ff",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"x": 1070,
"y": 100,
"id": "4064ca0.8313238",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": true,
"x": 1070,
"y": 240,
"id": "f862a862.af3dd8",
"type": "neviweb-account",
"z": "",
"url": "https://neviweb.com/api/",
"name": "MT"
This works! I can put the neviweb gateway in "Home" or "Away" modes reliably by injecting the 0 or 2 as the msg.topic
I would really like the other nodes to work. Any clues where things are going wrong in the github repo?
