I have this flow
when I try to deploy my flows I get this message Error: More than 1 database name in URL
here is my url : mongodb+srv://username:password1234@cluster0.hx0l5.mongodb.net/capteurs?retryWrites=true&w=majority
I have this flow
Might be due to specifying the database name "capteurs" in the host field and in the database field?
Try setting the connection host to the host name / cluster DNS name only (i.e. remove /capteurs) as suggested in the readme
I still have the same error
You currently have a full url in the Host field - including <username>:<password> and other details.
Have you tried with just the Host name in that field - cluster0.hx0l5.mongodb.net ?
yes but i get this error MongoError: failed to connect to server [cluster0.hx0l5.mongodb.net:27017]
Ah right - you're trying to use the srv record... I assume the node doesn't know how to work with those.
If I remember rightly, the hosted mongodb service can also provide you the 'normal' hostname/IP to use, rather than the +srv connection string.
Another possible reason .. although i havent worked with cloud based mongo dbs .. could be that Atlas server requires a step to whitelist an IP from where you want to access the cluster.
Add Your Connection IP Address to IP Access List
@sabayke Have you done this step ?
With the Compass tool.. can you connect to your cloud db ?
Also .. what mongodb node / version are you using ?
That configuration screenshot doesnt look like its the node-red-node-mongodb 0.2.4
Can you try the above node instead that is more often updated and its config has options closer to your needs
yes when i try to connect compass with my db it work nicely
ok i will do it
i have 2 versions
i guess you have to uninstall the other node first
i tried this
but i didn't change anything
you have to be in the c:\Users\owner\.node-red folder to run that command
and make sure node red is not running
but why dont you uninstall it from the Palette that is easier ?
first you have to delete any instances of the mongo nodes in your flows and also any Configuration nodes related to it
You are using again the whole string .. use only the server cluster0.hx0l5.mongodb.net in HOST
it work thank you so much
