How to generate Poisson distribution?
I am working on a project and I want to generate events in Poisson distribution form, the "event node" doesn't support Poisson, could you help me Please.
I don't recognise that node. Did you install this from the palette? If you look at the entry for this node in the flows library, there should be a link to the repository where you can ask the author for this additional feature.
I never used it, but did you try this node:
@Steve-Mcl, the node in question is node-red-contrib-random-event-generator.
@Salarj, please see my comment on the issue you raised on GitHub. If you want to continue this discussion, please do so either here or on GitHub, not in both places.
@mickym2, it is my impression that the node you mentioned provides values of the Poisson distribution, not events.
Thank you Dear for your response.
I saw your answer on GitHub.
your sincerely
