i use a NanoPi with ubuntu, snapd, node-red and want to manage WIFI settings via forms and exec nodes
My image comes with "nmcli" (Network manager cli) with works perfect via putty (command line)
http://wiki.friendlyarm.com/wiki/index.php/NanoPi_NEO2#WiFi
CLI commands works fine:
Via exec-nodes it is NOT possible to use the commands.
FYI:
Other cli-commands work fine (example "timedatectl")
What can i try? Can anybody gives me a tip?
Thank you
Alexander
Colin
2
Try giving it the full path to the nmcli command. which nmcli will tell you where it is.
Thank you Colin, but nothing changes:
ifconfig -a works fine!
iwconfig NOT
You are running in a snap which is a virtual environment. So nmcli is not included inside the snap.
By default we use strict confinement. You can relax that by using --classic mode..
Thx, good tip, I do more research.
So, i switched back to an "nativ" installation of node-red without snap.
In this case i can use NMCLI directly from Node-RED
I want to learn more about snapd, but at the moment i have not the time
I switched to snap because i had problems with connecting to ttyUSB0, But for that i also have found a solution. See this post:
