My NodeRED instance in running in the cloud. There is no hardware attached.
How can the 4 Rasberry PI nodes (keyboard, GPIO in/GPIO out) be removed from the Node palette at the left side?
I tried to "npm uninstall" something but these nodes are not installed by npm nor by the palette editor.
Those nodes are part of the core install of Node-RED - they are not separate modules you can remove with npm.
You have three options:
- leave them there
- open the Manage Palette dialog, find them under the 'node-red' module and disable them.
- edit your settings.js file and add a
nodeExcludes
entry that lists node files the runtime should ignore. You can see that in action with the default settings file we use in IBM Cloud - https://github.com/ibmets/node-red-bluemix-starter/blob/master/bluemix-settings.js#L47
IMHO option 2. is the easiest and removes them from the node pallet on the left side of the editor window.
