How to send a command like a real keyboard
i searched the whole day in the web, but i cannot find what i need.
could someone tell me how a commad (Raspberry pi with Rasbian) has to be that it simulate a real keybord input?
In my case i created a display with a raspberry which shows all time my google calender. Now i want to use some keyboard shortcuts for my web calender which runs in Chromium, like change the view from monthly to daily etc.
I want to trigger those shortcuts from a node which is controlled by Google-assistent, that´s why i´m want to start that command with a exec Node.
thanks in advance
Felix
As always, Internet search is your friend.
hi, this solution won´t work in a exec node, nothing happend to the chromium web site.
i tried it in the terminal and it typed me what i wrote in the command. hmm...
any other idea ?
Cannot be done directly, you will need something like selenium to simulate input from a “script” (there are many types of software like this, search for selenium alternative)
it works with xautomation ... just type the command.
Perfect , thx a lot for pushing me in the correct direction.
Nice, i learned something too :wink:
I'm not familiar with the xautomation, can you explain a bit more in detail how you got it to work? Thanks
xautomation(7) - Linux man page (die.net)
Ok I'm gonna need a little bit more info on this one.. So I need to install a node that can execute a xautomation command? and what is the xautomation command to send an F11?
maybe like 4th or 5th post here
Seems all a bit overkill for what I need. I wanted an icon on the desktop and open it in kiosk mode. I finally ended up using the next command and it works:
´´chromium-browser --kiosk http://localhost:1880/ui/´´
Thank you ! It work fine with exec Node with xautomation.
xte -x:0 'key a'
But,It don't work in remote desktop.
