Updated this morning and now the Inject Nodes are not "clickable."
EDIT: They come and go.
Please provide additional info.
Updated - from what version to what version?
How is node-red installed? docker? home assistant? other?
What OS is this running on?
What node version?
Running on HA, 4.0.3.
There seems to be a pattern developing here. Buttons on inject and debug node not active. Also HA.
Yep, I guessed as much too colin (but wanted confirmation from the OP)
@bkr1969 are your flows actually running?
Can you check the deploy dropdown - show me what state is has on the highlighted area?
PS, I am reliably informed this is not a new thing for HA users of node-red. Something to do with websockets.
FWIW, running V4.0.3 in docker, in k8s on FlowFuse and running locally (on metal / not docker) - I do NOT see this issue.
My flows appeared to run this morning, but I'm actually not sure if all of them did. It seems OK now. I also use Voice Monkey to interact with Alexa and I was getting errors that my targets didn't exist. Eventually they would work after triggering them manually through the Voice Monkey page and reloading.
While it started working at work (Windows) not working at all at home (Mac). Tried Chrome, Safari and the HA app. What is the problem and solution?
