Is it just me or has the Forum just updated?
I’m no longer getting an edit box on the left with preview on the right when editing a post. Instead there is a more advanced WYSIWYG edit box. Not all of which is actually easier to use - for example, using 3 backticks to start some code - you used to be able to put “```js" to get javascript highlighting. Now you have to type the backticks and then separately use your mouse to select the language.
Also, without the preview box, the edit box could easily and more comfortably be wider which would help with typing.
There is “fullscreen” button, but it seems to only centre the same editor window on the screen.
I looked quickly as the topic interested me, but then didn’t worry as I didn’t recognise what you were saying.
Went off and looked at another post and posted a reply.
Yes, SOMETHING has changed.
This is what I’m seeing now: (Cropped a bit)
And just to add: When I drag the picture into the edit part, it looks different.
Pressing at the end of a sentence/line gets TWO blank lines.
There is a new button up the top left shown here as the letter A.
B - I’m guessing is bold.
I - Underline.
Tr…. Shrug. Oh, sorry… Tt is it?
Yeah: something’s changed.
AH!
The A button…. Click it and you go back to the older way.
I was also wondering what was going on - thought it had something to do with my browser! When I put in the 4 back ticks (````) to post a flow, the text scooted over to one side and a drop down with different code (?) formatting options appeared.
The Tt button is headings.
Thanks.
So what what I posted the solution to your question?
(Guessing not)
Yes it does.
Yes, thanks. :slight_smile:
