Issues on installing node-red-contrib-auth-saml
For a node-red enterprise application trying to enable Single Sign On.
Planning to consider Azure AD as an Identity provider. Got an metadata xml file from Idp after registration.
Now the problem is integration with node-red.
Tried to follow node-red-contrib-auth-saml - npm. but there are some fields like
myissuereid- what to fill on this. and is this a correct approach?
while installing node-red-contrib-auth-saml some vulnerabilities[-32 vulnerabilities (9 low, 6 moderate, 17 high) ]
