Hi everybody.
I'm teaching IoT to a class of students, which are experiencing a problem in the MQTT connection.
MQTT (mosca) node is not successfully connecting and is giving this error:
schemaerror: Expected "schema" to be an object or boolean
Apparently is related to jsonschema? We found this.
The interesting thing is that just 6 out of 20 are experiencing the issue, possibly unrelated to the version of npm or node js (nothing changed when updated)
Thanks in advance for your help!
Edit1: a quick fix found by a student is shifting to Aedes[1]
[1] https://github.com/moscajs/aedes
mosca is a dead project & superseded by aedes.
How are you running a broker in your class lessons? - a shared broker (amongst students) I assume (for interaction)
Are you running aedes (formerlly mosca) under nodejs from command line?
If so, why not use just use the node-red broker node node-red-contrib-aedes - or for that matter install mosquito in a central location?
Hi Steve.
Thanks for the answer.
We did use aedes, yet everybody on his own node-red instance.
What we are trying to achieve are several interaction between a selfhosted Node-RED cloud and and Arduino MKR1010.
While Aedes is properly working within Node-RED, Arduino is having an hard time to connect to the broker.
I guess this problem is not related or addressed to this forum though.
Thanks for the quick answer!
so is that aedes or node-red-contrib-aedes?
This should work (aedes is a very reasonable broker) - assuming devices can contact the aedes IP:PORT (same network / no firewalls etc)
but again why not have a mosquito install?
