MQTT in node not working properly in Node-Red 2.2.1
Hi all.
I've a problem with MQTT in node I use mosquitto.
When i make full deploy (ex. move MQTT in node) I get this error back on the debug console,
"Error stopping node: Close timed out"
mosquitto version 2.0.11
mosquitto is an MQTT v5.0/v3.1.1/v3.1 broker.
I got the same issue so I disabled all my mqtt nodes, deployed and re-enabled them. It deploys without the error now.
Maybe this will work for you too?
Whoops, spoke too soon. It's back again!
Welcome to Node-RED
16 Feb 00:45:40 - [info] Node-RED version: v2.2.1
16 Feb 00:45:40 - [info] Node.js  version: v14.19.0
16 Feb 00:45:40 - [info] Linux 5.10.92-v7+ arm LE
16 Feb 00:45:41 - [info] Loading palette nodes
16 Feb 00:45:45 - [info] Dashboard version 3.1.5 started at /ui
16 Feb 00:45:46 - [info] Settings file  : /home/pi/.node-red/settings.js
16 Feb 00:45:46 - [info] HTTP Static    : /home/pi/.node-red/static
16 Feb 00:45:46 - [info] Context store  : 'default' [module=memory]
16 Feb 00:45:46 - [info] User directory : /home/pi/.node-red
16 Feb 00:45:46 - [warn] Projects disabled : editorTheme.projects.enabled=false
16 Feb 00:45:46 - [info] Flows file     : /home/pi/.node-red/flows.json
16 Feb 00:45:46 - [info] Server now running at http://127.0.0.1:1880/
Your flow credentials file is encrypted using a system-g...
(snip)
16 Feb 00:45:47 - [info] Starting flows
16 Feb 00:45:47 - [info] Started flows
16 Feb 00:45:47 - [info] [mqtt-broker:a6e18de3fc619133] Connected to broker: mqtt://192.168.1.11:1883
16 Feb 00:46:19 - [info] Stopping flows
16 Feb 00:46:34 - [error] [mqtt in:1eab723e3b975572] Error stopping node: Close timed out
16 Feb 00:46:34 - [info] Stopped flows
after you reenable have you then tried to move a mqtt node and deploy it? I still have the same error now also on the mqtt output node
feb 16 02:05:29 amc Node-RED[1069]: 16 Feb 02:05:29 - [info] Stopping flows
feb 16 02:05:44 amc Node-RED[1069]: 16 Feb 02:05:44 - [error] [mqtt out:MONITOR:TX] Error stopping node: Close timed out
feb 16 02:05:45 amc Node-RED[1069]: 16 Feb 02:05:44 - [info] Stopped flows
feb 16 02:05:45 amc Node-RED[1069]: 16 Feb 02:05:44 - [info] Starting flows
feb 16 02:05:45 amc Node-RED[1069]: 16 Feb 02:05:45 - [info] Started flows
Don't install any mqtt broker (ex. MOSQUITTO on my case) install only node red..
Not installing an Mqtt broker ? what if you need it ? :wink:
an update of Node-red to 2.2.2 was released a couple of days ago
addressing the "Error stopping node: Close timed out" issue.
Read here :
