Nest Learning Thermostat
I unboxed a Nest Learning Thermostat today, and not even wired it up yet, but already thinking about how I can integrate it into my node-RED flows :thinking:
Anyone else using this thermostat?
Seems like a no then Paul :frowning:
Maybe try on the Hardware category?
Post moved to Hardware.
Cart before horse, you should of check for api's before purchase.
I know works with nest has been removed , I believe it is now works with assistant.
This may help Thermostat  |  Device Access  |  Google Developers
I highly recommend genius hub (Uk EU Z-wave frequency) to others as i have installed a few and it is very expandable. Normally a straight swap of standard programmer, and has a api to.
API access wasn't a show stopper, but just some icing on the cake :wink:
Thanks for the link @E1cid , once I get some time to install the nest, I'll give this a try.
It's sad that a company like google find it necessary to charge $5 to register for device access, after users have stomped up $250 to buy the device!
(or is it a nominal charge to prove the user's identity?)
Paul I did have NEST working via IFTTT and NR
But I had one of the early ones so it was a long time ago
But was reconsidering re-integration so would be good to know how you get on
