Hi!
I have a netatmo doorbell, is it possible to integrate it into Node Red?
Thanks in advance.
Hi!
Thanks in advance.
Did you had a look at then Netatmo node?
Hi!
Yes I did but that is only for cameras, light and weather station. But not for the doorbell
I don't have their doorbell, but the API is somewhat generalized, I think you can get the status/events from doorbells too with this node (smart doorbell with camera)
Hi!
Many thanks for the answer.
I would only like to have if someone rings the bell then have an imput in Node Red.
I'm also very interested in that. Shouldn't that be solved with netatmo_event and incoming_call? Unfortunately I haven't managed to do it yet. Has anyone solved this by any chance?
Hi!
Thanks for the answer.
Can you send me the flow there?
You can paste it here. In order to make the flow importable it is necessary to surround it with three backticks (also known as a left quote or backquote ```)
flow goes here
[{"id":"6e7d784b95b899f2","type":"tab","label":"Flow 3","disabled":true,"info":"","env":[]},{"id":"47d1289ac800b705","type":"debug","z":"6e7d784b95b899f2","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":460,"y":80,"wires":[]},{"id":"96c6ebff7dd9b6f8","type":"server-events","z":"6e7d784b95b899f2","name":"","server":"22956fda.1d0ab","version":2,"eventType":"netatmo_event","exposeToHomeAssistant":false,"eventData":"{\"type\":\"incoming_call\"}","haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"\"\"","valueType":"str"}],"event_type":"","x":200,"y":100,"wires":[["47d1289ac800b705","10dff9663dcdd759"]]},{"id":"10dff9663dcdd759","type":"api-call-service","z":"6e7d784b95b899f2","name":"","server":"22956fda.1d0ab","version":5,"debugenabled":false,"domain":"light","service":"turn_on","areaId":[],"deviceId":["3a86e287f5bb4194a39e80e0c1c25911"],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":490,"y":200,"wires":[[]]},{"id":"22956fda.1d0ab","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]```
