Network monitoring : is there a way to monitor network traffic to and from Node-RED in a fine-grained way?
Howdy folks!
I've searched the forum and library for clues to this question, but didn't see anything specifically addressing it:
I maintain several N-R instances with many flows each. With something like nethogs, I can see network traffic volume to and from a N-R instance in general , but not to see which flows / nodes / etc are sending or receiving that traffic.
Is there a way for me to see this Tx / Rx information in a more fine-grained way, broken down at the flow or node level?
Thanks and happy New Year,
Nicholas
Viewed from the outside, there is little information that relates traffic to a specific node though if you are monitoring msg's via MQTT, websocket or another network transmission method, then you will have the _msgid property.
HTTP traffic from one of the UI's (the Editor for administration, or /ui for Dashboard, etc) again will not be easily relatable though in the Editor, I think that most nodes will have an ID that should be relatable.
Probably the easiest (and it isn't that easy - at least for a non-pro developer like me) method is to start up Node-RED with node.js's --inspect parameter. Then you can use something like VScode or one of the Chromium-based browsers (Vivaldi is good for example) to monitor the code as it executes.
