Node-google update calendar event
Hi there,
I was wondering if someone is experienced with updating google calendar events with the node-google? I am able to create events with the following function:
msg.payload = {
'colorId': 3,
'summary': 'summary',
'location': 'location',
'description': 'description.',
'start': {
'dateTime': '2018-11-08T15:00:00',
'timeZone': 'Europe/Zurich',
'end': {
'dateTime': '2018-11-08T19:00:00',
'event':{
'colorId': 'purple',
'foreground': 'purple',
i was wondering if anyone could help me to explain how to just send an update to change the colorId of the event..
the flow looks like this: inject->function->google calendar out...
Best Regards...
haven't used it in a while but I think you need to send it as #RRGGBB
thanks for your reply... I need to clarify my question. Creating an event with the above code and flow works fine. As well as the color of the event. I was wondering if someone has a solution to just update a created event and just change its color...
thanks for any help
Hello
i have read your post, and it seems you got the same problem as me.
I can create an event in the google agenda, but I absolutely don't know hos to modify, chnage, shift, delete it.
Did you get an answer? A solution?
Also have the same problem, wondering if we need to use the calendar API until a module is created directly https://developers.google.com/calendar/quickstart/js
