Great work.
I'm getting and "Unexpected error" when trying to change, create or delete key on flow_cred in project settings.
Great work.
Hi. Would you mind raising an issue on GitHub so that we catch and fix this for the release? Thanks
This issue is still present @ my 3.0-beta.4 installation:
Not sure if this is related to the other importMap issue but I get this when I try and import:
Node-red is on a Raspberry Pi, the browser is Firefox on Windows 10.
Browser cache is set to clear when Firefox is closed.
Issue remains after both computers are rebooted, so I assume all caches are clear?
Unfortunately It's not cache related and is definitely related to the known issue.
Linux Mint 20.3 installed new beta 4
1 Jul 20:14:00 - [info] Node-RED version: v3.0.0-beta.4
1 Jul 20:14:00 - [info] Node.js version: v18.1.0
1 Jul 20:14:00 - [info] Linux 5.4.0-120-generic x64 LE
and opened up localhost:1880. It does not go into the editor. It seems to hang up before it loads my flows. No controls are loaded to do anything.
PR established: https://github.com/node-red/node-red/pull/3730
I'm having a similar issue after the upgrade
yes, I deleted the 'settings.js' file. Incompatibilities exists from old settings.js file on older versions. Now it displays nodes for editing.
There shouldn't be - otherwise we'd have highlighted such a significant breaking change. Will investigate (I have a strong suspicion on what it'll be)
Thx Nick. Anyway for me recreating the settings.js hasn't worked.
Well, to be absolutely honest here, I did not intentionally delete settings.js because of any error messages leading me to do it.
It was in fact a completely unrelated, vague and wrong peace of information I recalled.
So I was in no way on any trace here, it was pure luck (or coincidence
The error loading the editor (where you get a blankish screen and Problem initialising 'monaco' code editor ReferenceError: monaco is not defined in the console) has been fixed in git for the next release.
The workaround is to ensure you settings.js file includes a codeEditor section under the editorTheme property. The current default settings.js file has this property.
editorTheme: {
codeEditor: { lib: 'monaco' }
Wow ... the switch to "monaco editor and some related entries in settings.js" was what I vaguely recalled and what let me delete the file in the first instance. Mh ... Off to the lottery now. It seems to be my day ![]()
Much thanks, as I have deleted the file and found success.
I do not need any credit at all @tree-frog. I just felt like the blind hen which found a grain of corn. And blind I was.
@jodelkoenig,
I tried to delete my flow file at first, but that had no affect. I only deleted the js file after someone here had suggested that fixed it. It's all good. You may have seen my attempt at 'Monty Python-esque' humor.
Since updating to beta4, I don't seem to be able to import any flows.
For example, if I try Import > Examples, and pick any flow, I get this error message;
A search of c262ada8.d4cd7 does not locate any such node in my flows (I assume that refers to the node ref in the example flow).
The same thing occurs if I try to import a flow (that I have just exported) - same error - different node ref.
This did not occur in beta3 as I loaded one of Bart's example flows last night OK.
I can't see any errors in the browser dev console (although I'm not the best to check!), and nothing in node-RED log.
Tried clearing browser cache, and also when using a new incognito window. Also restarted node-RED.
Node.js version: v14.19.3
Linux 5.10.103-v7+ arm LE on Pi 3B+
Same here Paul, but if you look at earlier posts it's a known issue.
Ah, the post above that says 'cannot import nodes'....
Not the best description ![]()
